No Start
No Start
I havn't been able to crack this issue alone so I need some guidance.
The car cranks just fine but no fuel is getting to the engine. I have replaced the DME and have checked for leaks but nada.
When you say "replaced the DME", did you also change the relay, which seems to be a common problem with no start issue. It would be a shame to go through the trouble to replace a DME only to find out it is the relay.
Good luck
Good luck
If its this one , I think I see the problem .
https://rennlist.com/forums/attachme...1&d=1189898490
https://rennlist.com/forums/attachme...1&d=1189898498
This will fix it up ,
https://rennlist.com/forums/964-forum/390894-exhaust-tip-polishing-101-a.html
https://rennlist.com/forums/showthread.php?t=390894
Just finished reading that thread.
Does this buzzing sound mean I need a new DME?
Is the fuel pump relay and the DME two different things?
I just put in a new fuel pump relay.
Quickest and dirtiest way of telling if the fuel pump is working is to remove the fuel line, and crank it over.....but mind the mess. I use a bottle to collect the fuel when I have done this, it pumps at a fair rate.
Careful as you go though.
Kevin.
Kevin.
"it pumps at a fair rate."
An understatement .
It will **** out a few gallons before you know what .
Use a big clean gas can as a catch can .
If you undo the line from the fuel filter , then clamp on a rubber tube to run to the catch can ...
Have a water hose and a fire extinguisher ready .
Don't burn down your house or your car .
Pull the car away from the house before doing this sort of thing .
Have you tried starting it on starter fluid ?
An understatement .
