My last CAT BYPASS call to action/advice . . .
I am about to pull the trigger on a cat bypass, but I want to do one more round of info gathering before doing so. (I already have a primary bypass.) Options:
I am tempted to go Dansk at about $550 (from EBS): apparently excellent quality, excellent fitment. Comments?
Fabspeed has, it seems, two cat bypasses: 964 European Pre-Muffler Catbypass Pipe ($375) and 964 Sport Race Catalytic Converter ($550). What are the major differences between these two? Compared to Dansk?
Then there is the Schnell Catalytic Bypass Exhaust Test Pipe - Catbypass T-304 Stainless Steel (15 lbs) that sells for $279. Anyone know much about it?
Other brands? Preferences? Opinions?
Any comments on performance/sound greatly appreciated.
Is this the Schnell one you were looking at:
http://www.vertexauto.com/ShowItem/3...st%20Pipe.aspx
It looks like it has a bung for the O sensor. And the price is half of the Dansk. Anyone used the Schnell? I might be inclined to get one at that price.
In general, anything called a bypass will be close to a straight pipe and not pass your State's emissions test. They're also a bit louder--think booming. Your neighbors will love you for it.
Joey--thanks. You may be right (although the primary bypass sound I have at present is relatively tame). There isn't an emissions test to worry about.
I would be curious about the noise level, though--I have heard a one recording of the cat bypass with primary bypass (cup pipe), and while it sounded rough, it didn't seem obnoxious. Any others out there running this combo?
And I should have added one more candidate to the cat bypass possibilities:
PORSCHE 964 C2 C4 RSA SPORT CATALYTIC CONVERTER 100 CELLS
PART#964SCC PRICE $399.99 from Maxspeed.
http://www.maxspeed-motorsports.com/964cat.html
1 Post
Aficionado
joey: the interior of the Dansk race catbypass is ceramic coated and will pass emissions test.
zicoramone:
Well Maybe..... it all depends on your state and the emissions levels they are looking at - for Wa (for instance) i would say there is an 80% chance you will pass w/o and issue with no Cat. For Ca. it is closer to 0%. In IL i have no experiance to gauge by.
it does eliminate the Cat, ceramic coatings are used for heat shielding and have nothing to do with the levels of emissions passed.
A Sport Cat is not an eliminator pipe - but a Catalytic converter that is higher flow - it should pass emissions w/o and issue but you are not eliminating the Cat converter just replacing it.
hope that makes sense
Kevin
Kevin.
Aficionado
zicoramone:
Looking at my pictures of what's inside the stock cat vs. the Dansk bypass, there's got to be much more free flow through there. I used an inspection mirror to look at the insides of the outer chamber and it appears there's nothing in there except that the inside of the outer wall of the cat bypass seems to be lined with a very, very thin layer of something (there's some texture there is probably the best way to describe it). Probably the ceramic Zico mentions.
As TR6 said earlier, it looks purty too. I'll have to dirty it up at inspection time so as not to attract attention.
BTW, I have the numbers from my last inspection with the OEM cat. I'll post up the difference next time I get emission checked with the bypass. That won't be until May though.
