I searched and found lots of info but because the car is old (89 C4) and has 49k on the clock I wasn't completely sure what to do.
So here's the thing. My clutch is in needing of replacement and as a result the engine will be pulled. A independent mechanic and I will be doing the work and wondered what else should be done while in there. He's where the difference comes in. The previous owner had the maintenance work done at a shop that has closed and I can't get any records (no receipts for work). So seeing how the car is almost 19 years old and has 50k, what should I replace or change. Should I do a 60k service? After my the car has sat for about 2 weeks I noticed a small amount of oil on the garage floor underneath the engine. Looks like it's seeping from the bottom of the engine. Any advice is greatly appreciated.
thanks for the tip. i will replace that seal. what could possibly be leaking at the bottom of the engine. it looks like where the two manifolds (if that's right) come together. it isn't leaking but rather just a little damp.
You don't need to pull the engine to replace the clutch.
If you pull it, I'd do a full 60k service and make sure you fix any leaks, check the power steering pump/belt and verify that the engine carrier is still in good shape. Clean and powdercoat the tin if it's getting rusty.
Replace all the "external" seals that are easily accessed while motor is out, like front main seal (flywheel side), power steering pump/cam seal, oil pressure sender unit seal, valve adjustment and new valve cover seals - that's about it for the easy ones that commonly leak.
Check out the condition of the clutch plate and flywheel.
Thanks for the tip. Where can I find information/part numbers on these seals? Would you not normally replace the clutch plate when doing a clutch job?
