More questions PROBLEM
I still have to diagnose a problem with my car.
I have already purchased and installed a new DME. Unsuccesful. Car still runs rough and will not straighten out and run smooth.
My car has run great all summer. This came out of nowhere. I do think it has to be ignition or 02 related. I replaced my 02 around March. Will they go bad this soon. I have a 1224 code also. Any diagnostic for the 02?
Any ideas are welcomed.........
Does your car start on either coil alone?
I had rough running that turned out to be coils.
Others on this forum have recently suggested that it is time to change out original coils anyway.
Not sure if that's been done on your car yet, but it might be a reasonable thing to try.
Oh, and go for the OE not OEM from pelican. The OEM's are bosch from Brazil and are poor quality.
Technical Guru
Code:
1 1 2 4 | | | | | | +--+- Fault Code | +------- Constant Fault (2 = loose contact) +---------- DME Control unit
Technical Guru
Originally Posted by MassGuy
just unplug and replug. Does this reset it or something? Do I need to buy a new one and replace this or what do you suggest?
The 02 is from Vertex and is OE or I just swapped them out. Non-universal. I will dig in today.
Jason I really need to Thank You.....you are always right there. It is apreciated.
