964 Forum 1989-1994
Leaking Base Seals
Old Oct 29, 2007 | 03:02 PM
  #31
drola's Avatar
drola
i checked out the ebs website. so far i figure i need to buy:
1) case(block) gasket set
2) head gasket set
3) timing chain gasket set
4) main bearing set
5) rod bearing set
6) arp bolts
7) rocker shaft seals
8) piston rings
9) fuel injector seals
10) flywheel bolts
11) #8 bearing (does this always need replacing or upon inspection)
i will let the machine shop tell me what the heads need.
can you think of anything else i might be overlooking?
