964 Forum 1989-1994
wheel spacers
Old Sep 16, 2007 | 09:54 PM
Dwane's Avatar
Dwane
Default wheel spacers
Anyone running wheel spacers, front or rear on DE days?
Currently running 5mm front and 13mm rear.
Does anyone have comments or concerns for DE's?
thanks
Dwane
Old Sep 17, 2007 | 12:51 AM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
What kind of spacers?
I run 7 mm spacers rear and 4 mm spacers front at the track but they are the type that just have holes that fit over the studs.
For the street, I use 18" rims that need a 21 mm spacer that have integrated studs but I would not use these at the track as the second set of lug nuts can not be checked.
Marc
Old Sep 17, 2007 | 09:47 AM
Ritter v4.0's Avatar
Ritter v4.0
Where are you guys sourcing your spacers- I can't find the sizes I'm looking for at the usual suspects (Vertex, Pelican, FleaBay etc)..
Old Sep 17, 2007 | 11:10 AM
kgorman's Avatar
kgorman
www.cdoc.com, http://www.automotion.com/, www.wheelenhancement.com no affil.
Old Sep 17, 2007 | 02:17 PM
Ritter v4.0
Thanks for this.
I don't see anything between 7mm and 14mm- i reckon I need 10-12mm.
Old Sep 17, 2007 | 07:43 PM
Dwane's Avatar
Dwane
The rears have the integrated studs.(H&R)
The fronts are the slip-on type.
I would have thought the rears would have been safe and the fronts unsafe.
What is the verdict?
Old Sep 18, 2007 | 01:29 AM
Boeing 717's Avatar
Boeing 717
Registered User
Hey Marc Shaw are you using 7mm without wheels stud inserts??? If so have you had any problems???
JERRY
Old Sep 18, 2007 | 11:46 AM
cobalt's Avatar
cobalt
When running the cup 1's 7 & 9's for AX or Street use I am running 6 mm front and 13mm rears the rears have the integrated studs and lip. I didn't like the 7mm front because it left too little lip and left the wheel with no centering lip so I am actually running 2-3mm spacers leaving about 2mm of lip to center the wheel.
I also replaced all my studs front and rear with longer ones. This allows me multiple options. For track use I am running 8 & 9.5 fikse's with proper offsets to fill the wheel wells so no spacers at all.
Here is my lovely wife pushing it at our Pocono AX event this past weekend, as you can see no rubbing even with 235/275 tires.
File Type: jpg
Old Sep 18, 2007 | 12:15 PM
Dwane's Avatar
Dwane
Anthony, Are you running with the alloy nuts?
Where did you get the studs?
Dwane
Old Sep 18, 2007 | 12:18 PM
Marc Shaw's Avatar
Marc Shaw
JERRY
Jerry,
I replaced the stock 45 mm studs with 52 mm front and 56 mm rear so I have no problem with thread length.
Marc
Old Sep 18, 2007 | 12:20 PM
Marc Shaw's Avatar
Marc Shaw
Originally Posted by d964
Are you running with the alloy nuts? Where did you get the studs?
I got my studs at www.pelicanparts.com and I got open top steel lug nuts from them too.
Marc
Old Sep 18, 2007 | 12:25 PM
cobalt's Avatar
cobalt
Originally Posted by Marc Shaw
Jerry,
Marc
Same here
Marc
I would not use aluminum lug nuts for competition events and i torque the steel lugs down to 100 pounds.
Old Sep 18, 2007 | 12:34 PM
ilko's Avatar
ilko
Agent Orange
FYI guys, I just got the open steel lug nuts. When I use them on the stock bolts the end on the lug nut is pretty much flush with the end of the bolt after properly torqued. I don't feel comfortable using any spacers with the stock size bolts, but that's just me.
Old Sep 18, 2007 | 12:45 PM
cobalt's Avatar
cobalt
There is enough length to the stock studs to use a 3mm spacer. I would not go more than that. The studs are relatively easy to replace and not to expensive an upgrade. In either case whatever spacer you use make sure at least some of the centering ring is accessible and that the wheel is not using the studs only to center and support the wheel.
Old Sep 18, 2007 | 03:13 PM
Ritter v4.0
If I can't find 12mm spacers, can I pair 6.5mm + 5mm for same (close) net effect?
