Soft top water stain on inside
Hi
The interior of my soft top has some water stains that i would like to remove. I removed the liner a couple of years ago as that was quite bad. But now it seems I have got a couple of stains on the inside of the hood itself. THey are only really seen when i put the hood down.
I am in the process of doing the waterproofing and wanted to get rid of these at the same time.
Any help welcome.
Rob
91 964 Cab
66 912 Coupe
Jersey, UK
Any help welcome.
Rob
91 964 Cab
66 912 Coupe
Jersey, UK
Not sure how to help, but if it's any consolation, my liner is rippped and needs replacing/removing. I took it to a specialist in Dallas, but they said I needed a new top. Everything seems fine to me, aside from the liner, so I think they were just trying to drum up business. Anyone else replaced or removed the soft top liner? What was the result? Are the stains noted by Rob common upon removal? Rob can you see the stains from the outside?
