cup spring rate
#31
Basic Site Sponsor
Basic Site Sponsor
Touche. Bet I'd be ahead if I were running slicks, even with a 250 lb disadvantage.
Seriously, the best thing that most drivers can do is to drive a car with a well setup non-adjustable suspension. Once the balance is right, all you have to do is drive the car. And it is the same from track to track. Trust me when I tell you that you really need to know your car, and you have to be very sensitive to changes in order to optimize an adjustable setup for each track.
If I were to recommend a good fixed suspension, 600/800 lb springs, custom valved Bilsteins and a quality set of adjustable sways bars would be the hot ticket.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#33
Your stiffer setup should be an advantage at a place like WG, so it would be interesting to see if it can make up for the weight disadvantage vs. the Cups.
#34
If you still have OS problems next weekend you might want to give the raise the spring rate in the front like I did. From what I understand you need to start w/ the gross adjusment first so: springs for general mid corner balance, then sways to fine tune (which should get your mid-corner just right), then shocks to fine tune entry and exit ...
Sorry to hear that you are slower on the new shocks w/ hohos...but that WILL change once you get everything dialed in.
Larry, Would agree with your suggestions on a non-adjustable setup. Most of my improvement will come from my driving and fiddling with the suspension has proven to be a distraction. I think the arrive and drive crowd is definitely on to something. All they worry about are laptimes and leave the rest to others.
#35
I have been sliding around the track with 95 nm/mm front and 180 nm/mm back.
This is something like 540 lbs/in front and ca 1000 lbs/in back
Previous owner vas not happy with the under steering cup springs and installed the Ôhlins based on the recommendations from the Öhlins expert / importer. The car got terrible over steer witch he believed vas from the stiff rear. Then I took over the car and tried out different damper setting and I have usually been backing out of the track.
I Norway we have slow tight tracks and I am gone try with 140 nm/mm rear springs (ca 700 lbs/in) and keep the front as is.
Please feel free to comment.
@ Arild
Kan du ringe meg.
@ Arild
Kan du ringe meg.
#36
"Seriously, the best thing that most drivers can do is to drive a car with a well setup non-adjustable suspension. Once the balance is right, all you have to do is drive the car. And it is the same from track to track. Trust me when I tell you that you really need to know your car, and you have to be very sensitive to changes in order to optimize an adjustable setup for each track.
If I were to recommend a good fixed suspension, 600/800 lb springs, custom valved Bilsteins and a quality set of adjustable sways bars would be the hot ticket."
I am with Larry on this one. My dad's 964 has the H&R Super Cup stuff in it with 964 RS sways. Works great at the tracks it goes to (SP, WG, VIR). For me adjusting the nut behind the wheel yields the most improvement in lap times.
#37
