CCU fan
CCU fan
To start with I have searched the threads but still need some assistance. Last night I replaced my last non working servo motor (drivers side air temp mixing). All went well but now it seems the fan in the CCU won’t stop running after I shut off the key. If I disconnect the battery it will be fine until the next power up. I have read on here that the fan can continue to run after the key is off. Mine never did this prior to replacing the servo. Is this true and if so for how long? I have let mine run for 10 minutes and it didn’t stop. I understand the function of the fan is to flow air to the CCU. What really is the down side of me unplugging the wires to the fan if mine is continuing to run? Thanks.
Yes, it's true. 20 minutes, give or take. The CCU stays powered to monitor the rear blower tube temps and a side effect of that is that the little fan behind the CCU stays on.
Check it after a half hour or so.
Hello,
Do not worry about it too much. The fan will indeed continue to run for what seems like far too long. You can pull out the CCU and unplug the fan, I have tried this and there does not seem to be much difference. This was not just something that I thought of out of the blue to do but was suggested while I was having my car serviced at a local shop.
Good Luck
Good Luck
