Stereo head unit replacement
Hi,
Yes, the L-shaped connector is routed to the amp, which is under the passenger seat for those cars that had it as an option. Maybe whoever installed your system just avoided the amp. I think the easy way out for my situation is to not use that factory amp and just wire directly from the new head unit to the speakers. I'd rather incorporate the amp if possible though.
Thanks,
Dan.
Thanks,
Dan.
Luckily, I happened to spot a thread on Rennlist by Rennlister adamfogerty:
https://rennlist.com/forums/showthre...ight=amp+cable in which he'd coincedentally found a guy in
Hongkong to build him a custom blaupunkt amp cable which mated an 8 pin DIN plug to the RCA inputs needed for the new head unit along with an amp wake cable.
Thanks in advance.
RIP
I'm doing the same thing today. Same Alpine Head Unit too. Difference is, I didn't buy the special cable. Now I need to know what to do about that "Amp Wake Cable." What is that anyway? I've cut open the amp harness and have (so far) soldered and heat shrinked the 4 RCA cables to the center conducter of the yellow, green, white and brown coaxial cables coming from the amp and have soldered the commons together. Now I have the red and blue cables left and the shield. Where do these connect on the head unit? I'm assuming the shield should connect to ground on the HU as it was in the stock HU. What about the red and blue coming from the amp? One of those must be connected to the "Amp Wake?"
Thanks in advance.
Thanks in advance.
I got it. It was the red wire in the cable to the amp that I connected to the blue wire from the HU harness. I'll post my amp cable findings later.
On another note, how did the alpine bezel work for you? Mine didn't fit very well and then it cracked. Otherwise, I am very pleased. The sound is so much better than before. I was beginning to doubt that the Infinity's and MB Quarts I installed this winter were lousy.
Thanks for the write-up. I even used the ashtray lamp suggestion. Just wish I had bought the cable harness. Going back to stock will be very difficult now.
RIP
1 Post
nice install, and great head unit....but imo, investment in new speakers/head unit without replacing stock amp (which really is a weak unit and genuinely produces poor quality sound) is like taking bath with your sweatsocks on.
Totally agreed. Further - for all you guys working on "adaptors" - I'd strongly recommend DIRECTLY supplying the HU with a 8-10G wire (fused) right from the battery. The routing of this cabling is a bitch in a 964 - but doable and the additoinal current will help IMMENSELY with the new breed of fairly powerful HU's - like the Alpines. That change ALONE can make a huge difference with power and bass response.
RK
RK
I fitted that very same head unit last year with new comps and an alpine swd sub, sounds good now
I binned the fac amp, it is old and under powered. The alpine head unit is allmost twice as powerfull.
