964 Forum 1989-1994
Noise?
Old Jul 20, 2007 | 04:55 PM
964russ's Avatar
964russ
Default Noise?
How loud is my car?
Does any one know how loud a 964 with only the last box is?
Track days r a bit funny with noise limits.
Old Jul 21, 2007 | 10:30 AM
Superunknown's Avatar
Superunknown
Mine with cat bypass, cup pipe and drilled airbox measured 108db at 4500rmp!
Old Jul 21, 2007 | 07:38 PM
SimonExtreme's Avatar
SimonExtreme
My RS with a cat bypass, cup pipe and drilled airbox is about 105db at 4500rpm . That was with the clutch in, which reduces the noise! On "noisy" trackdays, which normally allow 105db, I am just careful how far I rev the engine to.
However, on almost all other trackdays, you will not get on. You need to look at alternatives, such as the original system.
Old Jul 21, 2007 | 10:07 PM
964russ's Avatar
964russ
108ish? is vloud. most tracks wont let me run at that sort ov noise. Oulton park is my local track, and its a very good track and very strict on noise.
Iam goin to bribe my way on! Its the only way.
Money makes the world go round.... ha ha....
Old Jul 21, 2007 | 10:17 PM
964russ's Avatar
964russ
just checked at oulton "106db" is the limit! how loud is my car?
Iam runnin no cat and only the last box!
I havent got access to a noise reader?
My car is v loud it sounds awesome IMHO
Dont wana pay for a track day then get turned away for bein a noisy tw*t, u know wot i mean!!!
Old Jul 21, 2007 | 10:19 PM
964russ's Avatar
964russ
108? 105? thats very close.
Wot do i do?
Old Jul 22, 2007 | 10:08 AM
SimonExtreme
I have the same set up on my RS and never been turned away from Oulton Park. Go for it. Don't forget to depress the clutch as that reduces noise (on a LWF).
Old Jul 22, 2007 | 10:23 AM
911addict's Avatar
911addict
It seems to me that often they don't even check.
Until you test your car you won't know how many DB's. Many loud sounding cars are still within the limits.
Old Jul 22, 2007 | 06:59 PM
madmoog's Avatar
madmoog
my 3.8 C2 was tested a couple of weeks ago at Bedford and was 97db at a shade over 4k (98 being the limit), but apparently peaked at 101.5.
Seemed that everything there passed including quite a loud scooby, various GT£ and RS's lots of Loti, Monaro VXR etc.
