964 Forum 1989-1994
DME relay question
Old Jul 13, 2007 | 02:14 PM
ormy's Avatar
ormy
Default DME relay question
I've purchased a spare DME relay to keep in the glove box (as advised in many posts ).
I opened up the fuse box to look at the vintage of my current DME relay, and it has a 944... part code, which from what I understand, is the original DME relay. I've heard that this part was subsequently upgraded to a 993... part.
Question is - should I just bin the old relay anyway?
Old Jul 13, 2007 | 02:19 PM
Indycam's Avatar
Indycam
Is the new relay a 993 part number ?
If it is , put that one in and see if it works .
If it works , keep it in place , store the old one .
If the new one stops working you will have an old one to put it until you get another new one .
Old Jul 14, 2007 | 04:05 AM
ormy's Avatar
ormy
Sorry - I should have said the new one is a 993 code. I'll put that one in today and keep the old one as a back-up.
Old Jul 14, 2007 | 06:14 AM
david@st ives's Avatar
david@st ives
I keep a 3 pronged wire with spade connectors in my glove box as an emergency measure.
My relay failed within 3 months of ownership.
Dave
Old Jul 15, 2007 | 11:28 AM
ormy's Avatar
ormy
The new relay seems to have made a difference to the idling (for the better). Before, if I approached a set of traffic lights and came to a stop, the idling used to vary up and down for a few seconds before settling. I'd get worried that the car was going to stall. Now the revs just drop straight to the idling speed with no hunting.
I'm not sure if it's related to the DME relay, but things seem better!
Old Jul 15, 2007 | 12:21 PM
Indycam's Avatar
Indycam
Put the old one back in for a test ?
Does the funny idle come back ?
Old Jul 15, 2007 | 01:08 PM
ormy's Avatar
ormy
mmmmm... I put the old one back, went for a drive and the idling is fine. Do these things "reset" or something when unplugged?
Old Jul 15, 2007 | 11:29 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
The DME control unit's idle speed sensor adaptation value is stored in volatile memory so pulling the power will reset it.
