964 Forum 1989-1994
Rear wiper hole plug?
Old 07-11-2007, 06:28 AM
964rh
964rh's Avatar
Default Rear wiper hole plug?
Hi
Just about to take the rear wiper off the C4 and wondered what you can use to plug the hole in the glass so, a - it's waterproof and b - without wind noise?
Rob
Old 07-11-2007, 07:06 AM
Computamedic
Computamedic's Avatar
Rob,
ProMax do one - click here . Just under £20 + VAT & Carriage I assume.
Regards
Dave
Old 07-11-2007, 09:21 AM
Jeff Curtis
Jeff Curtis's Avatar
I used the 944 part, two gaskets, plug and large washer - worked fine although the hole in the 964 window for the wiper is a bit larger than on a 944, if I recall...the solution that robh suggested might be a "cleaner" install?
Either way, the 944 part worked great.
Old 07-13-2007, 02:22 AM
Group911@aol.com
Group911@aol.com's Avatar
I have a factory 964 one.
Old 07-13-2007, 06:21 AM
964rh
964rh's Avatar
Have you got the part numbers for the factory 964 one please?
Old 07-13-2007, 10:46 AM
a964man
a964man's Avatar
The Promax one seems the better option, I have the factory part, it cost me £47.00 ouch!
Old 07-13-2007, 01:23 PM
964russ
964russ's Avatar
think ill get one of them for mine, when my Heigo rollbar turns up. Thanks
Quick Reply: Rear wiper hole plug?
