Help with brake upgrade ideas.
#46
Originally Posted by Bill Verburg
964 C2, RSA and C4 rears are identical small body&pad 28/30 for 24mm rotors, RS and 964 turbo are the same small body&pad, but have 30/34 pistons and want 28mm rotors.
993 n/a C2, C2S rears are the small body&pad 30/34mm piston but want 24mm rotors
993C4 n/a C4 rears are the small body&pad 28/30mm pistons and want 24mm rotors ie they are the same as the 964 C2, RSA, C4 rears
993tt rears are 28/28, large body&pad and want 28mm rotors
993RS rears are 30/36, large body&pad and want 28mm rotors
A C2 w/ the 2piston calipers can profit from fitting any of the 28/30 small body&pad 24mm rotor calipers
A c2 w/ big red front can profit from fitting any of the 30/34 small body&pad 24mm rotor calipers
RS use a 25.4mm electro hydraulic m/c
C4, and turbo all use a 23.8mm electro hydraulic m/c, all of the other 964s use a vacuum boosted 20.64mm m/c
The 993 vacuum boosted m/c is 23.8mm and should be used w/ any combp of 36/44 front and 30/34 rear calipers. The smaller 20.6 may work but the pedal feel is very much improved w/ the bigger m/c
when using stock 36/40 front 28/30 rear the stock 964 20.6 mm m/c is fine.
Ok, seems like the way to go:
Front: 993tt/928GTS caliper with 965 rotor + FVD adapter
Rear: 993 C2 caliper with 964 rotor and no adapter
MC: 993 C2 23.8 mm, are there any modifications required to fit this mc on 964C2? Is it a bolt on?
Proportion valve: WHICH ONE?
Now, if only someone knew why I wanna do this, as I'm actually pretty happy with my stock brakes
#47
Originally Posted by rideshootanddrink
Excellent info Bill, thank you!
Now, if only someone knew why I wanna do this, as I'm actually pretty happy with my stock brakes![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
Why are you going to do this. To be honest my stock brakes were fine I happened to have spare set of front rotors and calipers so I decided to upgrade my C2. The improvement is tremendous. Not in the sense of stopping distance as much as modulation, control and far less dive. You don't have to be as hard on this set up as the stock brakes. No fade on the track (this was 3 days running 8-20min sessions a day with the 2 drivers) and better overall control, not to mention how much better they look.
So yes the stock brakes are adequate but the big reds are better.
#48
Bill Gregory did a very nice write up on adapting the 993 23.8mm m/c to a 964.
The article was in the June and July 2005 issue of Pano
I thought a copy was here on Rennlist somewhere but I couldn't find it.
If you don't have access to the above, pm your e-mail address and I'll send you a copy.
The m/c size available for use on a 964 are 20.6mm(standard), 23.8mm(turbo) and 25.4mm(RS). The first is properly sized for easy application of boosted stock brakes by a very wide range of physical abilities, the second is designed for the larger turbo brakes for the same population. The last is designed for track use of the same turbo size brakes by the more physically fit end of the population.
The bigger the m/c relative to the slave cylinders(within reason) the better control is obtained from the system. The high hard pedal is far easier to modulate than the slightly softer stock pedal. The slightly softer pedal gives you more gain from the system(less leg is needed) at the cost of control. These are each compromised toward a slightly different end.
#49
IHI KING!
So as not to confuse the issue, I replaced my 2 pots with calipers from a 968. Some 944 and 968 calipers are identical to the 964's. The C4 caliper is the same 4pot to which we are referring.
I went to a site that listed brake pad dimensions - that is how I found out Porsche model calipers would fit. Then I just widened my search for used calipers to include those models.
If you switch from 2 to 4 pot rears, you will want to replace the proportioning valve from the stock 2 pot 45 to the 4 pot 55 Bar.
Thanks in advance.
#50
#51
Yes, that is the 55bar p/v that you will want for 4 pot 28/30 rears
#52
I think that rear 964 RS needs 24 mm rotors. not 28.
Paolo
Paolo
#53
That is correct, the 964RS uses the same size 24x299 rotors as the n/a 964 and 993, but they are drilled & vented 951 M030 parts rather than the stock solid face & vented ones.
The 964RS rear calipers used the same 30/34 pistons as the 965 and later 993. The 965 calipers want 28x299 rotors the 993 and 964RS want 24x299 as on the n/a 964.
#54
I'm losing the will to live on this issue..
Ok - with the current exchange rates, i feel now is the time to buy.
I'm getting a full front big red kit from FVD. (£1000) but i found a kit from GMP in the US for $1650 = under £800).... anyway... big reds up front.
For the rear - 964 RS rotors, part no. 951 352 041 91...
these will work with std 1992 964 4 pot calipers, but should be upgraded to 993 C2 calipers yes?
i just need all this confirmed by someone who with the knowledge...
thanks in advance!
thanks in advance!
#55
thanks in advance!
thanks in advance!
#57
I've been looking a while now for some 993 C4 rear calipers to replace my 2 pots but have had not luck
So I'd like to widen my search to other models.
There is mention in this thread of 968 calipers been used (but these are also hard to come by) so I've browsed a number of the PET catalogues and see a number of potential sources for appropriate small body 28/30 calipers including the 944T and 928S4. The recurring theme on part numbers is:
xxx.352.421.xx (422 for the other part of the pair)
Again according to PET I see:
928.352.421.03 is the part number for a 964 C4 rear caliper (left) and 928.352.421.00 is the part number for a 928 rear caliper (left).
Here's a picture of some 928 S4 rear calipers. They look an ideal candidate to me or am I missing something?
![](http://i32.photobucket.com/albums/d25/brksy16/928s4rears.jpg)
#58
#59
Where in the car is the brake p/v situated, so that I can change it for the 55bar version?
#60
