guts of a leaking longitudinal slave cylinder - search begins!
#31
Doesn't that plastic collar look like it once was a teflon back-up ring or anti- extrusion ring?
It prevents the oring from extruding out between the groove of the piston and the cylinder due to high fluid pressures. Those are available at a seal supplier. They're installed by soaking the in hot water and stretching over the piston.
![](http://www.americanseal.com/products/images/backup_viton_1_fig2.jpg)
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
#32
Kenny - how did you figure your blue part of the middle seal was leaking? Was it broken also?
Yep - I have the other C4's but I don't feel like crawling under there - my back has been way too sore these past couple weeks!
#33
#34
The lateral slave the same setup seal-wise; it just has a larger plunger that attaches to the piston and longer spring for more travel.
I've got two "sample" o-rings that I should receive sometime next week and I'll rebuild both of these and test them out. If they work, then we've found ourselves a fix!!!!
#36
I just called to check on the samples this guy told me he would put in the mail about 1.5 months ago and then again 3 weeks ago... well this other guy at this place says they don't send samples. Hmmm, I wonder what this guy was thinking? So now I am looking to find a different o-ring source. An 11mm x 1.8mm is the replacement size for the o-ring... and it needs to be made of EPDM...
#38
Boom! I blew another today at TH.
I think the MTTF for these units is about 10 track days for me. I am going to start budgeting it in. I have a spare I built up, so luckily I can just swap this one out and re-bleed, but for the next one I am going to need some seals!
Low speed corners tend to eat it alive I suspect. I am guessing it just overheats and the seal fails. Temperature is a factor, I am wondering how we spec a seal with the proper thermal requirements...
#40
In some of our high pressure hydraulic trim systems, there are seals that are built the way these seem to be "cut". Notice that both rings are cut at exactly the same place and the ends are cut with the same "angles".
The gaps are not as great on our trim units, but I wonder if these gaps have some interface with the center seal ring to cause a "shuttle valve" effect?
Makes me wonder, especially if you did not find the broken pieces. Just a thought , guys.
#42
Professor of Pending Projects
Hi Guys - this project went on the back-burner since I had a spare and have been running it with no issues since. Plus the guys who were supposedly sending me samples never followed through, and part way through this process decided they will no longer send samples, and that I had to spend $100 minimum for $0.10 o-rings! But I now have some time and will re-investigate what will work since it is quite a simple system that should be completely repairable with the correct o-ring (with or without using the blue collar).
Kenny - take some pics of your dead slave if possible; I am interested as to what melts - the o-ring, or the blue seal.
#45
Ok, here are the pics below. Notice how there seemed to be an event where the thing blew apart. The washer is cupped the split ring is broken in half. The seals look like they just turned to mush. Perhaps the seals went, then this cause the rest to blow apart.
I have a rebuilt cylinder I am going to put back into the car, and see how it works. I will need new seals to fix this one up.
![](http://www.gormanz.com/albums/rand/IMG_0495.sized.jpg)
![](http://www.gormanz.com/albums/rand/IMG_0496.sized.jpg)
![](http://www.gormanz.com/albums/rand/IMG_0503.sized.jpg)
