964 Forum 1989-1994
Hot weather performance ?
Old Jun 18, 2007 | 11:38 AM
Lew964's Avatar
Lew964
Default Hot weather performance ?
Does anyone notice any drop in performance during hot weather temperatures. I realise that cars like cold dense air for optimum performance but i can definetly feel a lack of umph in hot weather.
Old Jun 18, 2007 | 01:36 PM
springer3's Avatar
springer3
My butt dyno also detects significant loss of power on hot humid days. My theories, starting with the largest effect:
1) Knock sensors keep the ignition retarded.
2) Less air mass in 3.6 liter volume when it is hot.
3) AC on max robs about 5 hp, plus adds the rotating inertia of the compressor.
Old Jun 18, 2007 | 01:56 PM
Red rooster's Avatar
Red rooster
The 964 has maps to reset Timing/fuelling etc when the intake air temperature
rises . That looses power but inhibits knock ! Dont know what Motec does !!!!
All good stuff
Geoff
KS400200,the oldest 964 on Rennlist,unless you know differently !
Old Jun 18, 2007 | 02:14 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
The ignition timing is also reduced with the increase in intake air temperature. With the standard programming and 93 octane the knock sensors shouldn't see any activity.
To reach the upper temperature scale all you need is to drive around in the summer for 30 minutes and then get stuck in stop'n'go traffic. I was kinda surprised, with an RS3.8 wing and a cup airbox the temperatures were right up there.
Old Jun 18, 2007 | 11:33 PM
jneteler's Avatar
jneteler
From my days in aviation...
Every 4F increase in temperature is roughly the equivalent of an additional 1000ft of altitude. That is why a naturally aspirated car will perform better on a (relatively) cool day.
JNeteler
Old Jun 19, 2007 | 12:12 AM
SimonExtreme's Avatar
SimonExtreme
JNeteler
Also applies to Turbo engines. IIRC, for turbo engines in the 3-400bhp range, expect 10degrees c change to equate to 4 bhp.
