Anyone replace their climate control unit (CCU) with a more manual solution?
Mine is finnicky.. i want something I can turn the blower on full at any time - regardless the air temp in/out/engine.
I drove a 90 C4 coupe back with 9k miles in '96 and it was this way, and my 90 C4 Targa is acting the same way - so I'm not sure if it is normal or what..
But... I'd prefer just to have a manual temp slider and fan speed. Has anyone done this? I imagine it'd be somewhat simple (ahahahah!), with the wiring diagrams of the inputs and outputs.
Thoughts?
Thanks,
Mike
1990 964 C4 Targa
Thoughts?
Thanks,
Mike
1990 964 C4 Targa
You mention "air temp in/out/engine." Are you refering to the rear blower?
I'm confused, because unless your fan speed control ****/pot has a problem, can't you just crank the ****? Or push your defrost button, too (I think). Sorry, it's been a while since I played with mine.
If it is the rear blower, isn't a symptom of a failure in the rear ducting sensors (NPT resistor/temp sensor?) that it drives the rear blower to full? Sorry, once again, it's been a while. If so, is it possible (or safe) to install a switch between one of these and the CCU to make it think that the engine wants the additional (electrical fan) cooling?
As an aside, your post caught my eye as I did install a Rube Goldberg manual kludge into my HVAC.
My temp servos were not communicating well with my CCU temp slider, so I wired up a reversing toggle switch to a 9V battery to drive the flappers as desired. This works well as I only need to drive the servos off of full cold occasionally during the Florida winters. The device is enclosed within one of those tiny Radio Shack project boxes, and a wire is run into the trunk to two new servo plugs. Tastefully inellegant! Though, I think that it's time to send the CCU off to Loren.
No help, but good luck in your search.
