Fuel leaking under front of car
Searched and I am still not sure... Is the fuel pump under the tank?
I have a pretty bad leak, with fuel coming out of the front. Right side, just to the inside of the front right tire.
I assume the fuel pump is there and I need to replace the lines. Will know more when I have a chance to pull what looks like a cover off, on that side. (Appears the fuel is leaking around that plate.)
Been having that fuel odor for a little while, started getting worse recently.
Pulled into the garage today, and saw wet spots on the floor.
Some quick investigation, led me to the front where I saw a lot of fuel dripping out the bottom of the car.
Bill
Bill
Fixed it this evening.
No problem with the lines. The banjo bolt was loose. (See arrow in picture).
It started leaking more as I rolled it out. As I did, I noticed that the outlet line was not turning with the pump housing.
Tightenened it back up, test ran it, all is ok. I ended up tearing the boot on the end with the power leads... had to use a zip-tie to hold it back together. I think the fuel deteriorated the rubber.
The only downside is that my hands still smell like gasoline, even after washing them several times. I hate working with fuel!
Bill
Bill
