Motor Meister good/bad/indifferent?
I see a whole bunch of you say no way, bad idea.... but then again I don't hear that from ANYONE that has used them and said they they were bad except for posts from a long time ago. While I appreicate the comments.... anyone recently use them who was disappointed? Else it's hearsay.
Well the Pelican posts are pretty recent...
But its entirely up to you. Its your motor.
You are welcome to give it to them and report back with your results.
I rebuilt my motor myself last year.
When I first started looking into parts for my rebuild the Motor Meister ad looked great. They were going to supply a complete rebuild kit, and provide the required amounts of machining for a set price.
But when I checked into them on all the different Porsche sites, I felt it was too high a risk with my very expensive Porsche motor to deal with them.
I can tell you one thing that is not hearsay. Porsche motors are incredibly expensive and they require diligent attention to detail. Its not like rebuilding a chevy. A proper rebuild wil cost between 5k & 10k USD. And if someone gets in there and makes a mess, you can double that in the blink of an eye.
Kirk
Kirk
Thanks Kirk.
I'm rebuilding my 178k '90 C2. Never had any top or bottom work. I have a broken stud on #6 that causes oil leakage, quarter every 1k. Otherwise zero issues with this car.
Originally Posted by Indycam
"Isn't that what our engines are?"
Uh , did you get the little pedal car with the briggs and stratton ?
http://shop4.porsche.com/filestore.a...filetype=small
Where are you located elliotc?
I like others did my own, takes some time 6 months, $5K min. Look up Henry Schmidt on Pelican or Jerry Woods.
http://www.pelicanparts.com/techarti...ruce-jerry.htm
Check out Wayne Dempsy's book before you start
http://www.101projects.com/911-Rebuild/index.htm
Good luck.
Good luck.
