How to tell if you have LSD
RIP
My option code sticker is gone under my hood. I've wondered whether or not I had a limited slip differential. The PO did not mention it when I bought the car. A month or so ago I was having a cut tire replaced and I noticed the mechanic turned the rear wheel and the opposite wheel turned with it in the same direction. From what I understand a LSD will turn both wheels in the same direction while an open differential will turn the wheels in opposite directions with the transmission in neutral. I was encouraged, so I did some searching and found that for a 1991 and up USA manual C2's, if the 6th digit of the serial number is a "2" then it's LSD. If the 6th digit is a "1" then it's open. Lucky for me, the 6th digit on mine is a 2! The full number deciphered says that it's a G50/05 with LSD, #2020.
Steve
P.S. For a 1990 It's a "1" for LSD and "0" for open.
Steve
RIP
Originally Posted by David Ray
OK....Ask Timothy Leary! If you don't want to jack you car up - the infamous burn out!
Ha!
Sorry for the late response - I was away on a trip.
Steve
