Failed!!!!! high HC emmisions
I guess you are asking about the fan belt light .
When the fan belt breaks , a light on the dash lights up to tell you you are running without cooling and the motor will be toasty hot if you do not pull over and get a new fan belt on asap .
Seems obvious, but check the firing order on both distributor caps. #2 and #4 were swapped on the primary cap when I purchased the car. There was a recent dealer-service receipt for new caps and rotors, and a passing emissions report. The car ran fine, but better with the correct firing order on both distributors. Every firing order error will have a different outcome, and it is an easy mistake to make with 12 wires to keep straight.
Originally Posted by hawk911
can you ... be more specific as to what I'll disconnect?
