Bilstein (PSS9) Shock Installation Questions
Technical Guru
At the beginning of the year I purchased a used PSS9 setup from another Rennlister and sent them off to Bilstein for rebuilding. The rears were blown so it took a while to (get the parts and) rebuild the shocks so I just got them back yesterday. Unfortunately I have no documentation so I'm a little lost when it comes to the order of putting everything back together. Does anyone know the order of the pieces below from the front shocks? #1 is the original bump-stop so I don't need that? #3 (flange bushing) is for monoballs so I also don't need that? Is the proper order 2, 4, 8, 5, 7? or #2, 6, 8, 7 or ??? When I received the PSS9s they came with #2, 3, 4, 5, 7 and the original stock suspension came with #1, 6, 7 and 8. Does it look like I'm missing anything?
Can I install the rears as-is? I found a photo from Bill Gregory's RS installation that looks like he did exactly that but if anyone could confirm I would really appreciate it.
Agent Orange
IIRC the instructions that came with my shocks showed 2, 4, 8, 5, and 7. Do you have a spring compressor? You'll need it for the rear. LMK if you want me to send you mine. Just PM me your address.
Technical Guru
Jason, your rears look just fine (if they look like Bill's) since that mount matches the original style mount (three threaded studs). I would mount them right up!
What do you need a spring compressor for? Are those shocks that long you can't get them on without it? Hmmm.... those darn helper springs!
Technical Guru
This is my home-made tool for the front shocks
Originally Posted by JasonAndreas
I didn't want to take any chances damaging myself so I compressed the front springs when I removed the top shock/spring mount from the old assembly.
