Syndrome Strikes....
Today I went to replace my passenger door (right handside) interior light switch in the door jamb. I very carefully unscrewed and pulled out the old switch. I then carefully proceeded to clamp the wire and remove the switch. I successfully removed the old and installed the new and was just about to screw it all back together when disaster struck.......the wire snapped as I undid the clamp and is now lost inside the hole!
No amount of fishing around could apprehend the lost wire. I figured I could probably access via the wheel well so I removed the wheel and the liner but found to my dismay that I could not access the cavity from here nor could I access it from the interior panel or inside the luggage bay.
Can anyone advise? I'm sure I can't be the first to experience this bit of bad luck...or can I?
--H
PS. if bogiwhatsis still slums it over on this board, please...no rude remarks, sarcasm or caustic comments! :P
--H
Burgled
I did the same thing on my 911S. After spending a lot of time trying to fish it out I finally gave up and sold the car
The bad part is there isnt really any slack in the wire which makes it even worse. Sorry I couldnt help
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
The bad part is there isnt really any slack in the wire which makes it even worse. Sorry I couldnt help ![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Anyone know a way to access the cavity or any handy dandy hints for finding and securing the end of the wire?
Lifetime Member
Lifetime Member
Oh dear. So many times I've worried about doing that very thing! ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Hope you get it sorted, Howard.
P.S. Sorry - I know when we post something like this, every time there's a reply we expect it to be a solution...
Thanks John. What sucks about being afflicted with this particular syndrome is that it only strikes when you have really been very careful and taken painstaking steps to avoid the very pitfall that then bites you on the bum!
Hope all is well mate. Best to you,
--H
Lifetime Member
Lifetime Member
How about (very tricky to get at) via the instruments, H? Maybe if you take one out (the tacho might be the best as although it's further away, you might be able to find someone with a very thin arm...) - there must be access into there somehow and that seems to be the only place left.
Edit: Oh - it's the other side isn't it? Well how about taking the glovebox liner out and having a look-see?
Lifetime Member
Lifetime Member
OK, let's get inventive now.
If you can locate the wire at the light itself, you could splice it and run a new one down the front drain tube for the sunroof. Assuming that you can locate the latter and that you can feed a wire inside without making it leak (spot the next problem...
). This tube exits from further down the same panel as the light switch, so it kind of gets to the right area, though you'd still need some ingenuity to make it all work out.
P.S. I only just spotted the PS in your original post. Ha ha ha.
Maybe its just not accessible!?!
I am sure that someone must have had a similar experience (syndrome or nay) and found an easier solution?!
P.S. I only just spotted the PS in your original post. Ha ha ha. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Originally Posted by Indycam
Bore O scope ?
If you can see it, you can probably snag it. Do you have a dentist's mirror
and a flashlight? Blindly fishing about may have moved the wire from view,
but I'll bet you can bounce some light in there and have a look. Maybe if
you snap a picture of the opening, other's can visualize the task better.
I'm going out to look in my car for reference.
Howard, I just now changed my driver side switch. I used a hemostat to keep it from falling in. It definately has no slack. I don't know if it helps, but the wire goes up from the switch, not down. I'll bet it enters the post from behind the dash. The wire was too short to even tell what color it is. I soldered a 4" piece of wire onto it to make the installation easier, then put a piece of shrink tube on the splice. If you locate the wire behind the dash, add a short piece to it before you thread it into the hole.
