Syndrome Strikes....
Originally Posted by Fred's 964
Howard, I just now changed my driver side switch. I used a hemostat to keep it from falling in. It definitely has no slack. I don't know if it helps, but the wire goes up from the switch, not down. I'll bet it enters the post from behind the dash. The wire was too short to even tell what color it is. I soldered a 4" piece of wire onto it to make the installation easier, then put a piece of shrink tube on the splice. If you locate the wire behind the dash, add a short piece to it before you thread it into the hole.
I will probably have to solder on an extra length also as the breakage means its even shorter now!
Great advice, thanks!
