WTB: Power Window Motor
Anyone have a power window motor laying around they would like to sell?
Over the weekend my passenger side window stopped moving. I checked the switches with no luck and then pulled the door panel off to get to the motor. Measuring the voltage at the motor power leads, I get +/- 12V depending on which way I press the window switch. This tells me that the motor is indeed bad. I was able to get the motor out by itself by removing two torx screws. Measuring the resistance across the motor power leads shows an open.
Thanks,
Shawn
Thanks,
Shawn
