H4 Headlights
At any rate, here's data for what I bought:
Daniel Stern Lighting
url
http://www.danielsternlighting.com/tech/relays/relays.html
$348 headlamp ***'y, H4 Euro code, RHtraffic, genuine Bosch $174/ea
$ 55 Relay installation package RIK-H4R, 1ea
$ 57 85/80W Bulbs for headlamps (+spare)
If you leave the stock headlamp wiring untouched, you need to
limit your bulb wattage to
70/65w maximum ($19/ea).
If you upgrade the wiring, you can use
85/80w high efficacy ($19/ea),
100/90w ($18/ea) or
130/100w ($19/ea).
Recommend at least one spare bulb because these are all
nonstandard wattages. If you want to stick with stock
officially-legal wattage, the best ones are
60/55w ultra high efficacy, $17/ea.
All of these are German-made bulbs with proper colorless clear
glass, no blue phony-Xenon crapola here.
$ 8 Bulbs for city lights contained w/in headlamps. Use X6W, $3.98/ea
$ 27 Brakes, Reverse
Can also make your brake and front / rear turn signal lamps 40%
brighter for $6.10/bulb, your reversing (backup) lamps 100%
brighter for $7.20/bulb, front and rear sidemarker lights 40%
brighter for $3.98/bulb.
$495 Total
Order Items:
Qty SKU Product Ext
1 3934 H-4 Ultimate Headlight Package 439.00
2 1787 Trim Ring Screw, Small 6.00
2 1777 Trim Ring Screw, Large 16.00
I bought some pig tails online to convert from the original plugs to the H4 without cutting any wires. I will try to find that info, but so far am striking out.
I am using regular wattage bulbs. If I go higher wattage, I will install relays and direct wire rather than using the pigtails. My car is very low mileage, so I wanted to be able to revert to stock in case I sell to a collector. (1989 C4, 2500 miles when I bought it, 6000 miles now)
The H4 kit came with primered trim rings. These have been sent to Bumper Plugs for painting last week.
Order Items:
Qty SKU Product Ext
FWIW, I bought the H5 to H4 adpater kit from AJUSA:
http://www.ajusa.com/cgi-bin/stores/...b6ba67e6923aee
