18" Turbo Twist
I'm looking to purchase a used set of 18" Turbo Twist (8/10's) and wanted to know if these part numbers are the hollow or the solid spokes.
993.362.130.00
993.362.140.00
Also, will I need spacers? If so what size?
Thanks in advance!
993.362.130.00
993.362.140.00
Thanks in advance!
Hollow
993.362.136.00 - ET52 - 19.95 lb (front)
993.362.140.01 - ET65 - 23.36 lb (narrow body rear)
993.362.140.00 - ET40 - 25.13 lb (wide body rear)
Solid
8 x 18 - 993.362.136.01 - ET52 - 25.57 lb
10 x 18 - 993.362.140.04 - ET65 - 29.32 lb
10 x 18 - 993.362.140.03 - ET40 - 31.08 lb
The ET40 ones won't fit. The ET65s will with a 10-15mm spacer.
Solid
I have them, painted black. Mine are solid. 5mm spacers on the front, 21mm on the rear. I tried 15mm and they rubbed a lot on both sides.
I need to clear the oil line, which is flattened, so went a little wide in spacer. 19mm should be fine. I need to get the rear aligned and I think there needs to be more camber added to get 19mm spacers to work.
I have et52 front, et65 rear.
Mark
Mark
