964 Forum 1989-1994
Valve Service Question
Old Apr 26, 2007 | 04:00 PM
buellrunner's Avatar
buellrunner
Default Valve Service Question
Hey all,
My car is coming up to valve adjustment time. My motor isnt ticking at all...still sounds perfectly normal. What are the dangers or going over the reccomended valve intervals? Lets say the motor did need an adjustment (and I was wrong), and I continued to drive her for a few thousand miles. Would that/could that damage my motor?
Old Apr 26, 2007 | 05:29 PM
chancecasey's Avatar
chancecasey
likely will not damage anything if they sound ok but it will accelerate the normal wear & tear
Old Apr 26, 2007 | 05:32 PM
chancecasey
that's of course assuming they are loose, not tight. if you can smell them / if they are tight / then that can definitely cause damage, though normally they go loose and are only tight if adjusted incorrectly.
Old Apr 26, 2007 | 05:37 PM
buellrunner
If I can smell them? What do tight valves smell like?
Old Apr 26, 2007 | 06:35 PM
parsecnc4's Avatar
parsecnc4
I am curious on that too. Also, I would assume loose valves will also have issues with wear when it can be heard.
Old Apr 26, 2007 | 06:50 PM
chancecasey
Kind of a burning/burnt smell.
Old Apr 26, 2007 | 06:52 PM
WMRiceman's Avatar
WMRiceman
I have read that the wear point is the inter edge of the valve face. This causes the valves to tighten up over time. I've adjusted my valves now 4 times and found mine get tighter. In order for them to get loose, the shaft would have to compress (unlikely) or carbon builds up on the inter edge of the valve face. I wouldn't go past 15K. If your easy on the car, it might be fine. Mine spends most of it's time at the track so I adjust every 10k or so. Mark
Old Apr 26, 2007 | 07:25 PM
TR6's Avatar
TR6
Originally Posted by WMRiceman
...This causes the valves to tighten up over time. I've adjusted my valves now 4 times and found mine get tighter. ...
I've always heard the opposite about valves in general (not specifically Porsche)... That they get looser over time. I'm curious if anyone else has experience with 964 valves getting tighter as time goes by.
Old Apr 26, 2007 | 07:38 PM
chancecasey
Mine have always gotten looser. While the valve seating contact surface does wear (and make them tighter), more often the contact area between rocker arm and end of the valve wears down more quickly, making them looser. The other thing that might tighten them up is a head or cylinder lifting due to a head stud/nut loosening up - but of course that would be very bad. If you don't hear them and it's time to check - go ahead and give them a check - better safe than sorry. If they're too tight you'll burn a valve.
Turner's Avatar
Turner
Thats funny Chance. I thought they always kind of smelled like burning popcorn myself.
Old Apr 26, 2007 | 07:44 PM
TR6's Avatar
TR6
If it smells anything like leaking oil burning on heat exchangers, then I'm in trouble...
Old Apr 26, 2007 | 08:00 PM
chancecasey
It is a subtle difference - like a cab vs. a shiraz
Old Apr 27, 2007 | 08:02 AM
springer3's Avatar
springer3
I just finished a valve adjustment. Last time was 20,000 miles ago. All valves were still fine. I may go as much as 30,000 miles before I do it again. I drive on streets only, and US speed limits evidently keep the engine from needing adjustment as often as the factory recommends.
I would definately check if you do not completely trust the person that adjusted them last time. Not everyone takes a lot of care and I would worry about that except I personnally attended to it. I have seen blue cam lobes and blue rocker arms - overheated during a race because the valve seat evidenty was beaten in, or perhaps the valve head broke of and the motto was "press on regardless".
