Where can i find a cat bypass pipe??
I did back to back cat delete power tests and found very little cat removed bhp !
That was quite a few years ago so it could be that the cats being removed now are getting a bit exhaust flow limited !
The O2 should be in the cat bypass unless the DME is re-coded for non cat operation - not good !
Geoff
KS400200 , the oldest 964 on Rennlist , unless you know differently !
Geoff
I remember something about the Fabspeed catbypass not fitting well . . . or was it one of their other set-ups . . .?
Has anyone recently bought the Fabspeed catbypass and put it on, and were there fitment issues?
I need to know before making the leap to one . . .
Technical Guru
The MSRP for the official Porsche cat bypass (part no #964-111-042-05) for the 964 is $537.82USD. IF it is still available I'm sure you could probably find a dealer or two located in the USA that might sell them for under $300USD. Obviously there would be no fitment issues.
Originally Posted by Lew964
Installed my Cat by-pass last night and then took for a quick spin. From what i had read in the past i really wasn't expecting any noticeable increase in power, but on mine it definately has. At about 4500 rpm it really kicks in and seems to rev more freely to the red line. The noise, well it's a little louder, i have the secondary bypass aswell, it growls at low revs which doesn't attract unwanted attention then howls at you when booting it. A very combination and i wouldn't want it any louder.
The Oxygen sensor was a pig to remove and i ended up cutting it out of the cat.
Looking forward to the drive home from work now, bet the other 100 or so employees at my workplace can't say that !!!
![order](https://rennlist.com/forums/graemlins/order.gif)
I had the air inspection test yesterday after installing my cat pipe .. straight thru pipe with a fitting for o2 the sensor. Passed with no problem. I get my M&K muffler on Monday. I can't wait. I did not notice any appreciable hp change.
1 Post
I installed a Fabspeed cat bypass last month and found the fit to be just fine. The whole job took 20 minutes. Bysides all of the other reasons mentioned, I like getting rid of a big source of heat behind by left rear wheel. Obviously, the bypass pipe runs a lot cooler than the cat. The sound is terrific. Not much louder, but a little deeper.
Originally Posted by TR6
Ain't it great living in Texas? ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
No doubt awesome living in TX, except for all the recent rain which looks to be leaving us temporarily this week. Installed the M&K 1 in / 1 out to the catpipe. Wow ... what a sound. No resonating. Low deep rumble until you get on the throttle.
Question : Are there any Dallas / Fort Worth meets coming up?
1 Post
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
