Road handling of a lowered 964
A month in to 964 ownership and I think I'm beginning to get to grips with the handling of our cars. As each (dry) day passes I'm beginning to trust it more and more and am marvelling that if you take it by the scruff of the neck it will go round bends faster than you thought it would
. Straight line speed was of course, never in question
But, how does it behave on poorly maintained, bumpy roads? What do you experience, say, when hitting a bump or depression when doing 70+ mph? I know what happens to my lowered C2 but thought I would ask the question without colouring the water (so to speak).
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
This may or may not be in part an answer to your question but one thing I have learned to be very useful/important.
Tire pressure, I check it bi-weekly. I cannot believe what a difference this can make in handleing. My car did not handle well and I could not figure it out until I learned that all of my tires were at different pressures and down as much as 20 lbs. Duh now it handles like it should. My only excuse is that it was winter and to dam cold to really check it out.
Makes a huge difference.....
Yes I've got the tyre pressures right for my 17" wheels (36 at the rear and 34 at the front).
On good road surfaces the car is sweet and planted but hit a bump or depression at speed and it will kick off my intended line
. It feels like the affected wheel has temporarily lost contact with the road surface. I'm guessing this is a normal thing when running low/hard suspension as it can't soak up the undulations of the road as well as standard suspension.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Originally Posted by kusee pee
The stock suspension was far worse! The set-up was pretty poor beforehand too with heavy steering. It took me a while to get my confidence back in the car after the change because I couldn't believe the improvement. The rear shocks were done at the same time as the springs - maybe it's time to look at the front shocks if it feels a bit bouncey?
p.s. front shocks are going to be changed soon anyway (because of their age), I just haven't decided whether to go with the standard Boge or fit bilsteins.
I am in a similar situation and after some research decided to go with bilstein.No contest on performance it seems , but as a bonus i found somewhere selling them cheaper than Boge. Carnewal sell them for around 900 Euro full set of 4 with all taxes & postage.
PS - front struts only are 540 euro all in - way cheaper than Euro car parts etc.
Are you going to fit them yourself? I've seen DIY pages (Kevin's Warmfuzzies site is a good one) but can't decide if it's something I should be doing myself.
My car is lowered on RUF suspension - and although it handles bumps pretty well, on a twisty but bumpy road it will struggle. Just means I don't drive (quite) as fast on those roads.
