Torque Questions
Torque Questions
I just did a new clutch, valve adjustment, fuel injector cleaned and tested. Brakes and all new fluids. I have two manuals which would be more usefull for BTU units in the woodstove! If practice makes perfect, I must be gettin g better because it seems like I had to do allmost everything at least twice to get it right.
What are torque specs for: rear sway bar mounts, sway bar to drop link, motor mounts, tranny to body mounts. 1993 RSA
Alan
Alan
IHI KING!
Alan,
I just re-installed my engine/tranny in the car this past Sunday. Next weekend, I hope to have the remaining cables reattached and the car running again.
The torques are:
Tranny to body = 34 ft lbs
Engine to engine mounts = 62 ft lbs
Sway bar to body = 34 ft lbs
Sway bar to drop link = 63 ft lbs
Note: These numbers are from the Factory Repair manual
The torques are:
