Idle Problem
I have a 92 C4 with chip and secondary bypass as only known mods. Runs fine when driving, since yesterday I noticed a problem.
From cold, starts with maybe a half second of key. Runs smooth and purrs with no uneveness. After about 3 maybe 4 minutes will waver 3-4 times and die. Then will not idle unless out on the road or from cold start.
Any ideas? I was thinking vac leak or dirty intake.
I called today to get quotes on valve adjust and tune (comes with oil change). $900 was cheapest. Others where including brake bleed and front rear axle bleed that ran as high as $2700.
I have had this car less than a year and it has run flawless until now.
Thanks much for your time in advance.
Easy to check at DME.
Dave
