17" Tire pressures
Technical Guru
Originally Posted by boxsey911
Thanks again there was nothing in my manual about 17" tyres.
![](https://members.rennlist.com/jandreas/964-SteeringStops.gif)
and to check for enough clearance between the fender's metal edge and the front tires.
![](https://members.rennlist.com/jandreas/964-Tires-17-Body-Rework.gif)
Agent Orange
Hey Jason, is there a particular build date where the changes happened? I have a late March build MY91 with (what looks like) factory shaved fender metal edge and no rubbing whatsoever. I don't know if I have the 10mm steering stops, but it feels like I do.
Originally Posted by Red rooster
Steve,
Many years ago I used 2.5/3.0 on 17 rims once down the road. That was either chuck the tires in the trash bin or find out what to do !
Maybe I am not as brave as most people and if Porsche tell me what is needed I listen .
Be good to hear what happenes to you in the morning !!
All the best
Geoff
All the best
Geoff
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
It'll get a much sterner test in just over a month's time when it gets its first track outing
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Thanks guys, Steve
Technical Guru
After putting the 17'" cup wheels (Mille's) and Bridgestone RE750's on my 89 C4 I can't believe the difference in handling. I am running 36psi all around and the car just handles much better than the 16" wheels and tires. It feels like some of the understeer is also gone but that could be my imagination and roads I drove on this weekend.
What is the recommended pressure when using 225's on the front instead of 205's? I would guess that the original spec of 36 psi should be reduced by 1-2 psi.
I just purchased a set of Cup I replicas 7.5" / 9" from a fellow Rennlister with a set of Bridgestone S03's mounted, 225/45 front 255/40 rear. I love the look of the new wheels, how they fill out the fenders better than my original 16" Cups. The handling is better, but I haven't really put it to the test. I will post pics soon.
