Broken window switch
I broke my window switch yesterday and am unable to get the window back up. How can i get the window moved up before my new switch comes. The only part i broke off was the moving part you push up and down. The back part of it is still there.
I think so but how do you remove the switch? I'm not sure if i can just pull it right out or if the door panel has to come off. Does anyone know?
Isn't there a socket to crank the window up manually that you can access behind a speaker?
Think the crank is in your tool kit.
https://rennlist.com/forums/showthre...t=window+crank
Once you pry out the broken switch, do a search on repairing the switch. Takes about 15 minutes, and using 4 penny nailheads, it's good to go forever.
