964 Forum 1989-1994
Cup Car SPG mounting details
Old 05-09-2007, 01:22 PM
  #31
Cupcar#12
Cupcar#12's Avatar
Pictures of the motorsports side mounts (drivers side, L brackets)
i am assuming i have them on correctly - i will fit them to the car later thsi week hopefully
Old 05-09-2007, 01:50 PM
  #32
Cupcar
Cupcar's Avatar
That is the way the seat would go in the drivers side, the opposite direction for the brackets on the passenger side.
Old 05-09-2007, 02:24 PM
  #33
Cupcar#12
Cupcar#12's Avatar
great - it seems the logical way to put it together, bob. For the passanger side i have the Normal Recaro side mounts which position it in the center of the seat mounting brackets.
Did they make a right hand set (i would assume so for European customers) but......
i am going to switch out the stock seats for the recars for the parade (i think) it will be a punishing ride down there in June.
Old 05-09-2007, 02:56 PM
  #34
Cupcar
Cupcar's Avatar
You are right, I had a brain Frt, you can't reverse the mounts for the passenger side; the seat would have to be positioned to the right on that side.
To my knowledge the seat was only made to go on the drivers side as delivered by Porsche. When I've been in Germany and looked at an M003 Clubsport RS, which had the race seat on both sides, I didn't notice how the side plates were oriented, or what plates were used, on the passenger side.
I bet the seat and the mounts are the same in an M003 and the driver is to the center and the passenger is to the right.
Old 05-09-2007, 03:04 PM
  #35
Cupcar#12
Cupcar#12's Avatar
makes sense - no RHD Cups were produced so no need for them to be made.
Old 05-10-2007, 12:31 PM
  #36
Cupcar#12
Cupcar#12's Avatar
Installed in the Car..
A couple of notes...
1. You cannot use these with the stock seat belts - there is not enough room in between the center console and the seat once it is relocated. so only 5-6pt belts will work.
2. this moves the seat 2" to the center of the car - it feels better.
Old 07-31-2007, 02:54 PM
  #37
kgorman
kgorman's Avatar
Marc,
Which B-K part # are you referring to? R9062?
I just ordered a set for the drivers side just to see if that works, since I don't have access to the factory mounts.
http://www.livermoreperformance.com/...at_mounts.html
Originally Posted by Marc Shaw
That is exactly the same as the B-K mounts I have - they move the seat about 1/2" closer to the centre tunnel.
Marc
Old 07-31-2007, 03:37 PM
  #38
Tom W
Tom W's Avatar
I recently installed a SPG XL Pro Racer using the Recaro mounts and sliders. I had holes drilled lower than the normal Recaro holes in order to lower the seat a bit and get the angle to what was desired.
Kenny: Griffin Motorwerks in Berkley has the brackets (it's where I got my seat and brackets).
Old 07-31-2007, 04:21 PM
  #39
CWay27
CWay27's Avatar
Now it all makes sence, I knew my seat was off centered but couldn't figure what to do to remedy(since both sides are flared). Maybe we could do the same (like in Cupcar's picture) with the brey krause mounts R9062 (reverse one side) since the base plate is sloted. Kgorman, was that your plan??
Old 07-31-2007, 05:34 PM
  #40
kgorman
kgorman's Avatar
Thats the plan, yeap. I will post pics if it works out.
Old 07-31-2007, 06:43 PM
  #41
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Originally Posted by kgorman
Marc,
Kenny - I'll check when I get home tonight but I think that is the right number.
Marc
Old 08-03-2007, 03:18 AM
  #42
kgorman
kgorman's Avatar
Thanks Marc. Any news?
Old 08-03-2007, 12:16 PM
  #43
Marc Shaw
Marc Shaw's Avatar
Sorry - forgot to look.....tonight - I promise.
Marc
Old 08-03-2007, 05:31 PM
  #44
kgorman
kgorman's Avatar
hehe, no problem! thanks for your help!
Old 08-03-2007, 11:53 PM
  #45
Marc Shaw
Marc Shaw's Avatar
No, it was 9063 but they did not fit the SPG XL - only the SPG.
Marc
Quick Reply: Cup Car SPG mounting details
