GT3 Seats in 964
GT3 Seats in 964
Does anyone have GT3 seats in their 964? If so, can you post some pics?
Also, does anybody have the dimensions of the seats?
Thanks.
Thanks.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I don't have the exact measurements but the "bucket" is the same has Recaro Pople position, I'm sure you'll be able to find this from any good Recaro distributor. You can fit the seat and rails from a 996 into your 964 with minor mods if you are not too tall.
To use everything from a 996, you will need to bend slightly the rails front tabs and saw the guide pins since they won't match the holes in your car (floor bracket). Don't worry, not a big thing since your stock seats don't even have them. Now the seats will fit but you'll find that they are too straight. You can add some shims in the front but you'll need to get longer bolts.
Or just go buy a kit from Breykrause or FVD.
Here are pictures of my first set in savannah and second set in black.
