RSA Roll Bar ?
RSA Cage/bar
The safety devices cage is a nice peice, I have one in my rs racecar, and $900 is a steal, I wish I had seen it. Two issues to be aware of, the SD "bolt in" cage/bar requires drilling 25mm holes for welding in nutplates at each of the four main cage locations, and drilling and welding in support plates at the rear wheel wells. Additionally the fitment of the main hoop in the RSA requires boxing in the baseplate (something I found out after getting the full cage from Stable Energies) so this is not a simple bolt in job like the DAS bar, its really a "weld in the baseplates and then bolt it in" deal.
It's still a great deal, just don't want you to be suprised if you were looking for a two hour install...
With the DAS bar I actually notched the corners of the storage bin, and slid it up under the bar, jockied the whole thing into position and bolted everything down, end result is pretty nice looking and I still have the package tray and rollbar.
I'll try and post some picts of both
DAS bolt in roll bar RSA non sunroof
I have a bolt in DAS bar for a non sunroof RSA or the unlikely non sunroof 993. It was removed from a 93 RSA that had a full custome cage installed in it .
$750.00 firm.
This is located in Oklahoma City but i get to Dallas most every week. I will also be attending club races in Birmingham AL, College Station TX and Road Atlanta in the next 4 weeks if someone wanted to pick it up at one of those events. It can also be shipped via ups but the shipping is not cheap.
Cory Jump
I am also looking for a used 964 engine if anyone knows of one available. Either good for rebuild or good used engine or prepped stock class race motor.
$750.00 firm.
Cory Jump
thanks J, that was what I wanted to Know.
n/m
