964 Forum 1989-1994
First electrical gremlin!
Old 01-15-2007, 10:37 PM
NACHTBLAU
NACHTBLAU's Avatar
Tony,
Thanks for the link. I have the same problem and will be attempting to fix it soon. Did you end up writing up a DIY with pics?
Thanks,
Ryan
Old 01-16-2007, 02:02 AM
Lorenfb
Lorenfb's Avatar
"Take some comfot and try not to stress too much because the climate control in the 964 is s**t compared to almost any other car."
Not true! Actually, the 964/993 CCU system is a very well designed system. The CCU ECU is very
reliable and rarely if ever fails, e.g. usually when over-voltaged (charging), missing engine ground
wires, & reversed battery "jumps". The other major system problems are the result of the servo
motors and engine compartment connections, i.e. motor resistor/circuit breaker & temp sensor.
The majority of the time (+90%), the CCU is mis-diagnosed as the failure point when it's the
other system elements causing the malfunction.
Old 01-16-2007, 06:12 PM
Colin 90 C2
Colin 90 C2's Avatar
I had a similar problem with the intermittent blower. After much useless troubleshooting, I discovered that the electrical contacts from the blower wiring had been pushed back into the connector housing.
they are easy to push back.
It may be a long shot but that's what happened to me.
Quick Reply: First electrical gremlin!
