help with flywheel sender wiring
Hello,
I need help with the bosch sender wiring flywheel. When you look at the plug which one is postive ground and what is the third. I see the wiring on pet but no info on the make up of the harness.
Mark
Mark
Technical Guru
Originally Posted by kleinbbc2
Hello,
Pin #2 (brown) is Speed/Reference sensor shield (pin #48 on DME)
