Front Trunk Light Switch
Technical Guru
Could someone please take a look at the light switch that is part of the front trunk locking mechanism and take a picture or let me know if yours looks different from the one in the image below? I'm trying to find out what if anything is missing, possibly a spring?
![](https://members.rennlist.com/jandreas/FrontTrunkLockMechanism.jpg)
Jason,
I'm confused. AFAIK the luggage compartment light is operated by a switch up near the right hand hinge. I wasn't aware of ANY electrical connection to the latch mechanism.
Regards
Dave
Regards
Dave
Jason,
I, too, seem to have no electrics to the latch mechanism and do have a light switch within the rhs hinge.
I tried to take some pics, but my camera died and the phone pics were useless. I'll take some later when the camera has charged up again, but the plastic cover over my latch hides most of the interesting bits.
Cheers,
Dave
P.S. Mines a 91 with a Sept 19, 1990 build date.
Cheers,
Dave
Jason, On my '94 Speedster there is a micro-switch under the passenger side bolt on the latch mechanism. On my '91 cab there was a pin switch near the passenger side hinge. Must be a change in the later cars.
Here are a couple of pics of my front trunk latch and a shot of the light switch on the rhs hinge.
By the way, the red wire showing through in the 2nd pic is from the battery tender. I don't see any electrics near the latch itself.
Hope this helps.
Cheers,
Dave
Hope this helps.
Cheers,
Dave
Technical Guru
![](https://members.rennlist.com/jandreas/FrontTrunkMicroswitch.jpg)
Originally Posted by Smokin
My light is not hooked up. I've been wondering about this too!
Originally Posted by Jeffnudd
Im was pretty sure the switch in the catch is for a alarm?
Technical Guru
Thank You so much for the photos! (everytime I edit my post I notice additional images popping up in your message
) If you manually operate the locking mechanism does the trunk light go off? I can manually operate the switch by pushing the metal tab portion (red arrow with ??? in the image below) but closing the trunk doesn't have the same effect. Is there anything like a spring sitting between that metal tab and the pivoting arm or is there anything on your locking mechanism that is missing from my photos? In the first photo you posted it doesn't look to be the case so now I'm wondering if just bending the tab would fix the light.
Jason, the little tab on mine seems to sit down lower than on yours. When I pull it down (grabbing from below) it makes contact inside the switch and turns the light off. My tab resides just below the latch part I pointed to with the green arrow on your photo. That part must be what causes the switch to make contact when the trunk is closed. Need more pics?
Cheers,
Steve
Cheers,
Steve
