RS America Spoiler wanted!!!
At the time I could'nt locate an RSA decklid so I purchased an 89 Carrera lid from PartsHeaven. As you can see from the pics it is not an identical match on the radius and the side gap is a little large but it was close enough for me. The hinges did not match up so we just drilled into the new lid and used the same hinge. I can now reuse the old lid in the future if I choose. Joel at PCA gave me a part no. to adapt the hinges but I gave up on this. You can read my posting and his response there if you desire. There is also a way to override the warning light if you do this. Unfortunately, 90 cars are different than 91-94 on how you disable this light. I believe I paid $800 or so for the lid and the respray was another $700 ior $800. Not cheap. Thanks and good luck. This is the fiirst time to post pics so they may come under later posting.
Nice conversion. I had no idea the gaps were not the same. I guess you could find a C2 deck lid and take out the power spoiler and refit the Carrera tail to it for a more perfect fit.
The RSA tails also do not have a rear wiper plug location making them easy to see. As for performance any whale tale will work great on the C2.
Also you can just pull the bulb on the tail warning light. I did the plug conversion, but still can faintly hear the realy click on when the old tail would be going up and down. But with a seondary by pass it is pretty hard to hear.
Originally Posted by Tom W
I looked for one for a while, but most folk wanted $1k (and more) for them and an aftermarket one from MA Shaw or Getty Design was less than $750 (new). I bought the MA Shaw one. It lacks the rubber edge of the original (which I thought was ugly anyway).
JimC
I had an original 3.2 wing / decklid fitted to my 1991 C2. Later I swapped it for my current carbon wing-***-decklid that has exactly the same shape as the 3.2 liter but wheighs only 4kg instead of 20kg.
JimC
Originally Posted by hjcarlin72
How did the MA Shaw spoiler fit? Were you happy with the result vs a stock RSA Spoiler?
JimC
JimC
Originally Posted by Michael Delaney
I have one of these I will sell. It is currently white. I have the RSA tail and decklid complete. These are factory parts in nearly perfect condition, and I will not separate them. Let me know if that's what you want. I will include my home made aluminum adaptors to make this fit a normal 964 without changing the hinges. Also have directions to jump the moveable tail connector so the light will not activate. Regards, Roy
Mike,
I would be interested in the entire set up for my white 1990 C2. I have sent you a P.M. Thank you very much . Hope to hear from you soon.
Cobracarrera
JimC
JimC
Originally Posted by ChaseN
I just put on a MAShaw CF RSA wing, and I gotta say, perfect fit. Factory couldnt have been better.
Professor of Pending Projects
Originally Posted by Chris M.
Got any pics? I'd also like to see how those 996 wheels look on a 964.
