Speedometer ass'y. What are the parts that make it up?
Hi all. I'm having a weird patterned speedometer problem and I need to learn exactly how the assembly works so I can go upon trying to fix it. I think once I learn how it works and how the speed is read, it will be an easy thing to diagnose.
My questions are:
--Where on the car is the speed reading taken?
--What other things does the signal go through before plugging into the back of the speedo?
Thnx,
Harry
My questions are:
Thnx,
Harry
Technical Guru
Technical Guru
Hopefully I can get this figured out. Until then, the car sits! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Originally Posted by JasonAndreas
The first thing you should do is pop the gauge out from the dashboard and then clean the pin contacts on the rear of the speedometer with a pencil eraser.
Technical Guru
Originally Posted by parsecnc4
Pencil eraser? This is the first I heard of this and is interested in trying.
How hard is it to pull the speedo and does it need special tools or require extra care to avoid breaking tabs?
Over time the pin contacts have problems with carbon buildup or oxidation (possibly from frettage corrosion?) and eventually the resistance is high enough to stop the gauge(s) from working. With a pencil eraser you can remove the carbon from the pins and the instruments will operate as new.
It's not that difficult but the few times I've removed my gauges I started on the far left gauge and worked my way to the right. No special tools were required.
Tape up the end of a small putty knife to protect everything. Place edge of knife underlip of gauge rim and work the gauge out carefully. Go easy at first to make sure the rime and glass don't come flying off. You might find it easier to remove the clock and then reach in and push the speedo out.
