Hot all the time
My car has objected to me waking it up at 5am on a freezing morning by trying to melt me.
Monday started it to go to work. turned heater up full and its stayed that way.
I even with fan turned off and heat turned to blue on controller I get full heat and very fast air being pummped through.
I assume the air is comming from the rear blower.
Any ideas where to start? just looked at adrians book and there is a flap at the back does anybody have a picture of where this is located.
Thanks.
Thanks.
I have just found in Adrians book a test for the front 2 mixing servos's.
Not sure if this si where the fault lies because of teh amount of air blowing through from the rear
The outlet
The flap
Pesty, Check your heater duct tubes behind the left and right kick panels as well. Mine were old and had holes in them which allowed the flapper valves to remain open regardless of the mixing servo settings and allowed the hot air blown through the heat exchangers to enter the cabin. Replacing these fixed my problem. Only $20 U.S. per tube. If your heat comes through the vents then this is probably not your problem. Good luck.
Steve
Edit: Here's my before and after pics of the left side heater tube.
Steve
OK seems to be a success but not sure about a few things.
Tested servo's, Left one looking from front not moving. removed lever for flap still wont move. took out of car and applied 12v to 4+5 wont move.
Stripped apart and removed black crud from fingers. re assembled and tested it now moves ! yay.
fitted back in car no air blowing valve moves. So now I will not have to have window open on teh way to work at 5am
Now heres the observation I was not happy about. When the valve moves to its extreme possision it flexes the motor assembley its as if the motor is turning the lever too far. Thinking about it. I wonder if the arm that attaches to the rod moved a little when I assembled it all back together. I should have marked its exact possition beofre I dissasembled maybe?
The other thing is the rear blower is on full all the time and stays on for around 10 minutes. Just starting the engine turns it on full and it satays on even when I turn it off straight away. It was coming on at 5am at temperatures of around 1 degree celcious as soon as I started the engine. I assume there is something wrong there?
