Have I just overfilled??
A very embarrassing problem has appeared and I hope it is just down to my stupidity. I think I may have overfilled with oil after a guesstimate addition at the weekend. Since then my symptoms are thus:
Car runs fine but when I make a hard right turn (sharp roundabout or a t-junction) and then accelerate the car leaves a huge cloud of smoke for the next half-mile, scaring children and causing a local solar-eclipse. Then all is fine again.
What have I done??
What have I done??
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Haven't checked dipstick yet (LAZY BUGGER!) and the gauge shows plenty in there at the moment - which I expect to quickly go down as I continue to send smoke-signals to the world...
If the gauge is pegged to the top of the scale when the engine is idling you probably have overfilled it. If you add oil while the engine is ticking over, keep an eye on the gauge through the back window and stop when the gauge shows at 9 o'clock or a little over and you'll avoid the problem you now have.
You also run the risk of contaminating the air flow device in the inlet manifold since excess oil will get vented to the inlet. If the overfill is just a little it will probably be OK but I've never seen plumes of smoke on a small overfill.
Regards
Dave
Regards
Dave
Cheers guys - this also makes me realise why I had to have a new air-flow meter a while back (yes, I have done this before...!). Nothing like not learning from your own mistakes. Self-inflicted wounds are always the most amusing...!
Your's is not as bad as mine - I had to run it for about 10 miles before it cleaned up. I found a thorough cleaning is not necessary, since my breather hose seems to bring some oil into the system no matter what. I only took off the right side of the intake and pour out most of the oil or sop it up - a 1/2 hr job. Every time I've opened it, it had oil, but no smoke so I figure I saved 3.5 hrs.
The right side is easy to take off. Just take off your air cleaner, unbolt the metal cable holder, back off the screws holding the intake to the AFM and the three intake tubes and then wiggle free. Check out the intake cleaning procedure in the DIY section. Just remember to click the drop down box and select "from the beginning"... Otherwise you won't see any DIY procedures since none have been added within the last 75 days.
Super Duper Moderator
Marc
Man of Way Too Many Avatars
John Walker of Seattle told me overfilling is not bad in a 964 and will do no damage like in the older cars. When I drove mine back from Cali I thought I had done that and called him to see what I should do. He said if you do just let it burn itself out. major smoke clouds. If he says it is okay then I am sure it is.
Originally Posted by aeroman
John Walker of Seattle told me overfilling is not bad in a 964 and will do no damage like in the older cars. When I drove mine back from Cali I thought I had done that and called him to see what I should do. He said if you do just let it burn itself out. major smoke clouds. If he says it is okay then I am sure it is. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thats what John Walker who is one of the best Porsche mechanics in this area said. I can't remember exactly what he said is different but that it was bad on older models but not on 964. Just big smoke.
It seems like a rite of passage - I freaked because I thought I overfilled mine too a few months back - but I hadn't quite really over filled it... maybe just to 10:30 or 11:00
The guys at Gerber motorsports in Seattle told me if it's pegged on the gauge - they have a good laugh and would recommend draining a bit. John Walker sent me to Gerber because he was too busy last time I called!
Aeroman - where are you in the area? cheers, Brad
