1991 C2 versus 87-89 Carrera
I just joined tonight and have decided to try out this forum thing...
I am looking to buy my first Porsche and had a local Porsche shop recommend to me that I should get a 1987-89 and stay away from the early 964's. That said, I have found a great looking 1991 C2 with 90,500 miles. What kind of expensive problems can I be in for if I get this car? I have read in Excellence about the DMF, head gasket and distributor problems - the Porsche mechanic basically confirmed these things today on the phone.
With this particular 1991 C2, the owner states that he has:
- completed a top end re-build with new valve guides. This was brought on by oil consumption, apparently due to worn guides.
- the clutch was replaced at the same time, OEM flywheel was retained
- all the head studs were replaced with SS ones
- new distributor belt
I sure would appreciate some thoughts on this.
Thanks,
Dan
Much of what your tech says is true, however the 964 is by far the better car in terms of looks, brakes and performance. Stuff that cannot really be said about the 933 over a 964.
Your tech is right in pointing out some of the problems area's. Top-end are typically redone at 100K miles - although there are cars out there with 150K+ and no rebuild. DMF's failed however most have already been changed within the first 40K. Headbolts can leak - fixed during the topend rebuild, C4 transmissions can be a problem however most are caused by electrical problems rather than mechanical issues. Servicing is more expensive however this (IMHO) is due to there being 12 spark plugs to change rather than 6. Distributor belts can snap - caused by ozone build up, however there is a $10 fix for this and do not forget the rear lights go pinky!
However for me it was a no brainer. The 964 has ABS, power steering and with a few simple mods can be raised to 280bhp with little effort. Brakes are good and it handles really well + it has iconic Porsche styling without those nasty 3.2 bumpers.
Looking at the work already done on the 964 you are looking at its sounds a good one (providing the body and paint are good) as all the major points are covered, however before buying I would recommend a PPI as I would with any Porsche.
Other bits to check.
Should have a good service history
Front wishbone rubbers can become cracked and in need of replacment.
A/C Working- (+ converted to a ozone friendly gas)
Interior Trim should be in fine order - can be expensive replace
Oil pressue should be between 4-5 under acceleration and 1 at idle.
Rust around the front and rear screen - not a prosche problem, but caused by idiots damaging the metalwork when replacing the glass.
Should pull like a train when you boot it.
Other than that all the other points you would check on a normal car.
Hope this helps
Andy
Have you driven both cars? A friend has a 3.2 that I drive all the time (check my avatar). They are both great cars but night and day different. 3.2 has no power steering so if you're looking at a lot of city driving it's going to require a little more effort. 964 is much quicker. What will you do with the car? Daily driver? DEs? Club racing? Weekend fun car? Answering these questions will help us help you!
c
A well sorted 3.2 is awesome. I owned 2 over a 6 year period as daily drivers. True they are harder work to drive but if you want 'pure' they are fabulous!! And simpler and cheaper to run, generally.
No aircon though, but it doesn't usually work on the later cars anyway ...
But the 964 drives a lot nicer and feels less old fashioned.
cheers stu
I will be using this car as a weekend driver and perhaps a one day per week commute to work car. With every car that I have owned to date I have done all my own wrenching and intend to be able to do that with a Porsche as well. With it not being needed as a daily driver, I will have the time to do the maint and repair work slowly unitil I get profient with the workings of a Porsche.
I will phone the mechanic that has maintained this car for the currrent owner and find out the details on the top end rebuild as suggested. What components were replaced and with what part style etc..I will post this info as soon as I get it.
Am I correct to be thinking that updated parts are available from either Porche and/or afermarket to completely solve the 964 issues? If so and assuming the worst for the car that I am intersted, what is the approx cost of buying the parts that I would need to make this a solid and reliable performer? I could factor some of this cost into the purchase price perhaps.
Thanks!
I'm missing the '89 but I'm very happy with the '92.
Hello from a fellow Vancouverite. Here's my 2 cents worth:
1. As an admittedly biased '90 C2 owner I would have to say that the mechanical, styling, safety and creature comfort updates in the 964 make it a nicer drive.
2. If done properly the work already done on your candidate car is a fairly good insurance policy against major mechanical expense in the near future.
3. As already mentioned it would be good to know who did the engine work. I recently had my top end done and can share some insight into the local specialists if you would like.
4. Similarly for general service, are there good records and who did the work? Weissach, Scan, Targa and of course MCL are all top notch. There are other good independents too.Wouldn't hurt to talk to the mechanic who knows the car.
5. As with any purchase you have to pay a lot of attention to your general impression of the vehicle and whether any issues are either correctable or can be lived with.
6. And as others have said, if you're serious, get an inspection done.
If you have any other specific questions send me a private message. I'd be happy to help.
Jim G.
Ways the 964 is superior: brakes (including ABS), suspension, power (esp if you do some upgrades whereas the potential additional power is debateable with the Carerra) and HVAC system. Depending on the model 964 you get, you will also have stock 17" wheels on the car (vs. 16" on the Carerra).
The Carerra definitely gives you a 'rawer' experience and is a pleasure to drive. Maintenance is easier and a little cheaper (only 6 spark plugs to buy) and you don't need to deal with the 964's undertray (if you keep it on).
To me the 964 is definitely worth the few thousand dollar difference (it cost me $3500 to 'trade-up') - both cars were in the same condition and the 964 actually had fewer miles.
Just my 2 cents...
- the cylinders were re-ringed
- the OEM Nickasil cylinders were honed with a special hone (they were still within spec)
- valve guides were replaced with special magnesium bronze guide material
- guide and valve were each diamond honed as a pair to match
- this shop has been using this guide material for 9 years has had great success.
- the OEM DMF was left and the replaced clutch components were the updated Porsche units.
I now have to do a car inspection (I've only seen pictures so far)...about 3 hrs. away and from that determine if I proceed to a PPI. The key item would probably be the leak down test.
I apreciate all the tips and comments that you have all posted.
Comments welcomed!
