964 European front reflectors
Has anyone replaced the front bumperettes on a USA 964 with the clear euro reflector lenses? I took the cap off and I see two studs there. Another shop said I have to remove the complete bumper cover to get to the bumperette support and remove it before I can install these lenses. A different shop said I can unthread the studs from the front. Can anyone shed some light on this?
Thanks!!!
Chris
Thanks!!!
Chris
Most folks, including myself, cut the studs off with a dremel tool. You can then drill the rivet which holds the stud bracket inplace with a small drill and install the clear lense with a small sheet metal screw (#6 or #8, if I recall correctly).
Technical Guru
