Wood for drivers footwell?
Once upon a time I also had a woodworking hobby. Then I needed the garage bay for a third car that lived on the track and all the nice tools went to my brother or are sitting in a storage shed. And now that third car lives in a mobile garage and I have even less time for other fun stuff (like mountain biking).
This addiction is dangerous.
I also have the Rennline pedals and floorboard. Yes, they are expensive, but well made and functional. Covering the floor is simple sheet aluminum with non-skid strips.
I had a wood one in my car - it's sitting out back behind my house... might be warped.... but I haven't looked in a while! With size 12 shoes, I actually prefer no panel in there! If you want my home-made wood panel that fits perfectly and snug, and it's even painted, you can have it! I'll look for it tomorrow!
Super Duper Moderator
I didn't weigh just the stuff from the floors, but think it was about 20 lbs. IMO, it takes pretty radical efforts to make a big enough dent in the weight to see a performance difference and until you remove 200+ pounds you're not likely to notice much difference or see a big difference in lap times.
Marc
I searched http://www.cupcar.net/ and found on the parts list (http://www.cupcar.net/techlib/conten...ts_List_07.jpg) a part for 'pedal floor board left' 964 551 897 70. I think this is the correct part, can anyone confirm? Me wonders if it's still available.
Garrett, that is so nice of you! I am going to see if I can find a factory part, just because it's fun mainly not because it's any better than just a piece of plywood. ;-).
Tom, no it' not that the weight savings in itself is a big deal, but it's something. I have already done the 'big list' of weight reducing items including 10lbs off myself. I have removed 200+ lbs from the car at this point, the smaller stuff does add up!
The Rennlist stuff sure is nice looking though!
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
The suggestion of getting rid of all that foam and using a sheet of alum sounds like a great idea. I can then just place the factory floor mats on top of that. I just want to get rid of the foam and the brittle rubber covers that are under there. This will make for a nice weekend project. That Rennline floorboard sure is nice!
Originally Posted by Wachuko
You painted your car orange! or is that just the interior?? Anyway, looks good ![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
It is also not uncommon for the foam pads to be soaked with water and weigh about 10# each.
Originally Posted by forklift
Mine were soaked and weighed a lot. I have plywood on the driver's side and nothing on the passenger side. This is on the to do list, but I want to keep it cheaper than the rennline, so I might go wood again.
I have the plate under the pedals. I am talking about the floor boards: http://rennline.com/product.php/sid/...che/prodid/119
Of course I like the more expensive one that is a replica of the original in the Cup.
Your floors look good also. I tried that a few years ago, but my workmanship sucked and I just made a mess. My shop cut a quick plywood floor like the cups and I think I might just use that to cut a new one.
