Is this A/C Drain Damaged?
Cold water from the A/C system has been draining out of my ('91 C4) floor vents. I got under the car, and noticed the drain opening/slot appears to be bent?
Or is that the normal shape? I probed with a long screwdriver and some compressed air and felt a rubbery object (hose?) and pushed a bit. A fair amount of water poured out, but will need to drive it a while to see if this cleared the clog.
Thoughts?
Thoughts?
IHI KING!
I concur, your car is normal. See photos in this thread. https://rennlist.com/forums/showthre...ighlight=water
