Testing a LWF stalling solution
Technical Guru
So my RSA does not have air conditioning and not much of a LWF induced stalling problem so I'm in need of two (preferably with stock motors) USA based owners to help with testing before I start duplicating eproms for everyone. I'm looking for a MY89 or MY90 having a DME control unit with 911 part number and a MY91+ having a DME control unit with a 964 part number. You also need to have AC. If interested please contact me with a PM and once I find two people I will delete this thread.
Thanks,
--jason
Thanks,
--jason
My 90 has a 964 part number and 95 993 intakes and MAF with something done to the chip I am guessing. Have the stalling with a 7.5 lbs flywheel so I am hoping you can help me also....pleaseeeeeeee
Technical Guru
Originally Posted by Smokin
Where and how do I check that?
I have a 91 with a 964 part number. I'd be more than happy to help you out, Jason.
At present I don't have a stock chip; if that matters (except yours, of course).
Cheers,
Dave
Cheers,
Dave
All 964 DMEs are basically the same except for the EPROM, i.e. some have the
fuel quality switch & others don't but not an issue. Thus, most/all 964 owners
with a LWF should be able to help Jason do the evaluation.
Check here for the typical 964 Bosch DME part numbers which
can be used for the evaluation:
www.systemsc.com/Parts.htm
Loren, the voice of P-car knowledge has arrived! Jason, are you in NW CT or in MA? I'm 45 minutes away and other than 8/17 on (3 days at Summit point) i'll be around.. The 964 will be at Limerock on 8/26 for some "cleaning out" but will be a street car for a month afterwards..
This will be a great contribution by Jason in solving the LWF idle undershoot
problem (stalling) by either re-writing the u-P code for the dynamic 964 idle
system or by increasing the injector turn-on point, i.e. > ~ 1100 - 1300 RPMs.
Originally Posted by mbrouder
Re: our conversation via PM my part # is 911.618.124.01. According to 'the good book' that's from an 89.
Jason,
My 90 C2 has the 911.618.124.01 DME with the LWF + Andial "weight". I don't have a stalling problem, but if you want to try a chip in it, it's okay with me. (oh yeah, and it has AC)
