964 Forum 1989-1994
Dim Headlights...
Old Jul 26, 2006 | 02:35 PM
PorscheZen's Avatar
PorscheZen
Default Dim Headlights...
Newbie here.
I notice that my headlights are a bit dimmer than i'd like. Thinking of an easy upgrade by changing out the elements. Any suggestions?
Mention if I would need a relay swap-out and where I can get that too!
THanks!
Happy964...
Old Jul 26, 2006 | 02:45 PM
Youcef's Avatar
Youcef
Go here - https://rennlist.com/forums/964-forum/278458-hid-xenon-upgrade-photo.html, best upgrade you will make.
Old Jul 26, 2006 | 04:17 PM
jimq's Avatar
jimq
Burgled
Silverstar bulbs also are a nice up grade. You can get them for a pretty good price on EBAY usualy about $20-25 a pair..
Old Jul 26, 2006 | 05:12 PM
last toy's Avatar
last toy
The headlights can be easily removed by unscrewing 3 screws. remove the halogen lamp and socket from the back of the unit and pour alcohol onto the lens thru the socket opening and let it sit for awhile. swirl the alcohol around adequately to remove the aging haze. remove alcohol and dry residual alcohol with hot hair blower. You have to make sure the lens is 100%dry or condensation will occur when the lamps are on for awhile. Replace the bulbs with Sylvania Silverstar lamps for $20 as suggested. You get clear lenses and white bright lighting for a little work and few bucks.
Old Jul 26, 2006 | 05:20 PM
jimq's Avatar
jimq
Burgled
https://rennlist.com/forums/diy-964-1989-1994-911/197272-how-to-clean-your-headlights.html
Old Jul 26, 2006 | 09:33 PM
911URGE's Avatar
911URGE
I second this procedure with Silverstar bulbs. Night to Day difference.
I could not see my bulbs or reflector thru the haze. I did not remove the adjustment ring from the lens though and I placed a few small Pec Pads (lint free soft 4x4's for optical equip) into the lens along with the alcohol to help wipe the haze away then I just fished them out. I let them dry in the sun for the day. I put my old bulbs in the Silverstar packaging as spares and tucked them in the trunk.
Old Jul 26, 2006 | 11:45 PM
PorscheZen's Avatar
PorscheZen
Default Question...
There are numerous different types of Silverstar bulbs on eBay.
(9003 - 07's, H4 ST's, H1 ST's , etc...) Which do I need to purchase?
Are there wattage ranges I need to consider?
Thanks everyone. I really appreciate the quick replies.
Old Jul 26, 2006 | 11:59 PM
jimq's Avatar
jimq
Burgled
Sylvania 9004
Old Jul 27, 2006 | 12:08 AM
PorscheZen's Avatar
PorscheZen
In the words of Paris Hilton: "You Roll..."
